Question really flat retractable projector screen
Discussion in 'Projectors, Screens & Video Processors' started by bull, Dec 19, 2018.
  1. bull
    bull
    Aug 17, 2018
    4
    Cork
    Hi All
    I have a new UST projector - Dell S718ql.
    This one is really ultra short throw. it projects from 15cm from a screen. As a result you can see all imperfections of the screen and I mean ALL of them. Something you wouldn't notice with a regular projector in here is very visible. It's due to a fact that the projector angle is very wide.
    To resolve that I need a really flat screen. Best would be fixed frame but can't have it, has to be retractable.
    I assume it should be tab tension. So here is my question:
    Looking for a screen:
    - has to be very flat
    - diagonal 100 - 110 inches
    - retractable
    - don't care about motorised (but it would be nice) or if it is CLR (using only at night)
    - budget 1k ...but something tells me I will have to go around 2k
    - did I mention it should be flat ;)
    I have my eyes on some Elite screen and recent new Optoma tab tension screen but ES get sometimes mixed reviews and Optoma is to new. Do I have to go with Da-lite or do you guys have any other recommendations?
    Thanks!
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,334
    The Borders
    +3,424
    We often use and supply Beamax Tenisoned options.
    Joe
  3. Mallardo
    Mallardo
    Apr 7, 2016
    477
    Manchester
    +440
    Absolutely. No way you will get anywhere near flat with a non tensioned screen.
