really flat and wide movies
Discussion in 'Desktop & Laptop Computers Forum' started by NaTT, Aug 27, 2004.
  1. NaTT
    NaTT
    May 27, 2003
    1,123
    Abbots Langley
    +77
    when playing from a HCPC (any DVD player) into the DVI input of my Pio 43MXE1. (1024*768)
    Now I know the screen doesn't have square pixels but this is a bit much!
    I'm typing away in windows right now and at least the screen is fully used.
    With widescreen DVDs only half the hight of the screen is used.
    My only screen settings are dot to dot and 4:3, the latter of which puts a prefectly scaled image of the movie in the centre of the screen but only using half the area.
    How do I fill the screen (perhaps at the expense of proper aspect ratio or some of the image)?
    My Component input allows a lot more screen options to fill the screen.
  2. Loafer316
    Loafer316
    Apr 8, 2003
    330
    Natt what software are you using to play the dvds? before i wallmounted my mxe1 i had it hooked up to my pc. when play dvd's via zoomplayer i set it to anamorphic setting so the it would be stretced vertically and the screens own 16:9 shape would put it in the right aspect ratio.
    If using powerdvd i would set it so 'keep aspect ratio' was turned off and then it would look perfect on the screen.
    hope this helps, although i must add this was via the VGA input and not DVI.
  3. NaTT
    NaTT
    May 27, 2003
    1,123
    Abbots Langley
    +77
    cheers loffa,
    fwiw I created a new resolution in Theater Tek which fills the screen. Probably not "proper" but nocks spots of any HDMI fed screen I've ever seen.
    I tried the VGA input but that didn't allow stretching either.
  4. philipb
    philipb
    Mar 6, 2002
    2,083
    63
    Swindon
    +170
    NaTT
    The AR adjustments in TT are your best option. My preference is to leave narrow black bars top and bottom. Filling the screen vertically makes it look a bit overstretched to me. TT2 when it arrives in a week or so should be even better.
    BTW, are you using ffdshow with TT? Smartens up the PQ quite a bit. There's a whole section on using ffdshow on the TT forums.
  5. Loafer316
    Loafer316
    Apr 8, 2003
    330
    Looks like i'll have to invest tin TT then!! tried messing arounf with Zoomplayer and couldn't really figure out the filters to use and how to compensate for the rectangular pixels etc...oh well all the fun in learning!!
  6. NaTT
    NaTT
    May 27, 2003
    1,123
    Abbots Langley
    +77
    nooo not using fddshow yet, I'll look into that thanks for the steer.
    now to sort out region free ness in TT. I'd not played any of my US discs on my PC before now. Appears my drive was region 2, so I've flashed it to 0, but WinXP pro is convinced I'm region 2. DVD genie isn't helping much either as it's adjustments to windows or TT don't seem to take....
  7. paul1672
    paul1672
    Jul 31, 2003
    2,605
    71
    norfolk
    +46
    give dvd region-free a try.
    thats what i use for my htpc and theatertek
    works everytime.
