really dumb optoma hd67 question
Discussion in 'Projectors, Screens & Video Processors' started by dom1234567, Nov 28, 2010.
  1. dom1234567
    dom1234567
    Nov 16, 2010
    95
    Birmingham
    I know its a really basic question but i really dont know much about projectors, i would like to know if the Optoma HD67 has built in speakers and if so, how loud and what is the quality like. I am also wondering as i have a home cinema sound system how i would connect it to the projector (i want the HD67 as a multimedia centre? with my PC, virgin/sky, xbox360, wii and (maybe if i buy one)ps3 all connected to the projector). I would like to know how to connect all these items to the projector so they all work.
  2. Chox1988
    Chox1988
    Mar 30, 2005
    16,793
    basingstoke
    +9,161
    I dont think it has speakers inbuilt but if it does they will be the equivalent of laptop speakers so not really an option.
    You've got quite a few options as to connections, whats your budget and what is the speaker set you've got?
  3. Brew Dees
    Brew Dees
    May 4, 2010
    320
    +33
    Yup it has speakers. They are a bit worse than my IBM Laptop speakers, kind of equivalent to my cheap-ish $10 ipod speakers I'd say.
  4. Tight Git
    Tight Git
    Mar 3, 2004
    6,331
    +597
    According to the spec, there's a mono integrated speaker producing 2 Watts.
    So I think we can conclude that we're not talking hi-fi here! :D
    But, why didn't you just Google it, as I've done? :confused:
  5. dom1234567
    dom1234567
    Nov 16, 2010
    95
    Birmingham
    Thanks for the good replies
    I know its nothing special but (as i currently have a TV with built in speakers and i never was really that moved by surround sound) a set of bush 100w 5.1 home cinema speakers and DVD player
  6. SteveCritten
    SteveCritten
    Aug 13, 2009
    10,982
    Caistor Lincs
    +4,679
    If you are connecting all those things you will need to buy seperates ie an amp and seperate speakers this will sound much better than an all in one and be more upgradeable in the future as you can buy better speakers at a later date!!!
