Really Confused
Discussion in 'What Is The Best TV For You?' started by Jerrysimon, Jul 10, 2018.
  1. Jerrysimon
    Jerrysimon
    Aug 26, 2004
    292
    +25
    I currently own a 4 year old Sony Full HD 55" TV.
    I need a TV for my PS4 so have decided to move this into the games room.
    I looked a while back at 4K HDR TVs but decided to hold out. I now see I can buy a nice 55" OLED Tv for around £1200. So great I thought and was about to jump on board.
    I then began to think about if I should go larger than 55" given that I view this tv from about 10' away.
    Reading on I found info and various charts that with this viewing distance I should jump to 65". Great I thought, but 65" OLEDs are over 2K so my budget suddenly seems incredibly streteched. That said I remember purchasing a 32" CRT for £999 25-30 years ago.
    Another thing that attracted me to OLED, was the viewing angle but as its only my wife and I sit in front of it most the time, I thought that's a lot of money to spend for a better viewing angle.
    Looking around I have found a Panasonic TX-58EX700B at under £650 which is 4K and HDR. It sounds like the only thing I am gaining here is HDR and a few inches bigger. I have ordered it from JL to try and return if ot happy I guess. Hopefully I will see a diffence from my existing set which cost £799 4 years ago!
    Is my logic correct or should I just jump and buy a £2K plus 65" OLED ?
  2. Dodgexander
    Dodgexander
    May 29, 2007
    15,207
    +4,407
    Hi Jerry I have replied to your PM but you posted this in the general section so have moved it here. There is a large difference in HDR between that Panasonic and other more expensive models but for normal day to day tv watching its fine.
  3. Jerrysimon
    Jerrysimon
    Aug 26, 2004
    292
    +25
    Yes thanks for your reply, happy for you to delete the post if you want :)
  4. BobTheViewer
    BobTheViewer
    Oct 16, 2008
    160
    28
    +41
    to get an idea of some low ball Panasonic prices their outlet get sets at these prices
    65EZ952 £2k (LG B7 @ £2k(Ish) with long warranty is a better buy)
    65EX750 £1k
    65EX700 £850
    58EX750 £750
    58EX700 £480
