HappyGilmore007
Established Member
I have lg c9 and want some nice sounding speakers to go with it.
The front speakers would need to go either side of the TV but would be close to the back wall and corners in the room so think this rules out floor standing.
For now I want two front speakers and a centre. Maybe later if needed I will add a sub and a very slim chance I might add some rears. From my understanding the centre is very important for voices to be clear? I often struggle to hear speaking over movies background noise.
I was thinking this build but I am far from a expert so hopefully someone can check it or advise if I am getting value for money or if there os anything better for not much more?
Denon x1600 £350
petertyson.co.uk
Q Acoustics 3050i £165
www.richersounds.com
Centre 3090i £119
homeavdirect.co.uk
Stands £90
Total £724
Good deal for audio quality? Or can I do a lot better?
Is it important to have a sub at this stage?
Any help appreciated please
Denon x1600 £350
Denon AVR-X1600H AV Receiver
Upgrade your home theatre with the Denon AVR-X1600H. With 145W per channel (6 ohms, 1 kHz, THD 1%, 1ch driven), this performance-tuned Denon AV receiver provides a truly immersive 3D audio experience.
Q Acoustics Q3020i (White)
Shop for Q Acoustics 3020I White Speaker Pair with Richer Sounds for expert advice and lowest prices guaranteed
Centre 3090i £119
Q Acoustics 3090Ci Centre Speaker - Graphite
Accurate Centre Speaker with twin 100mm (4”) and 22mm (0.9”) precision drivers can be shelf or cabinet mounted on its compliant pre-fitted rubber feet or wall-mounted on optional, dedicate brackets.
Stands £90
Q Acoustics 3000ST (Satin Black)
The perfect fit for the 3010 and 3020 speakers, the Q Acoustics 3000ST stands don't just look the part, they sound it too.Sonically matchedDesigned to match the 3010 and 3020 speakers, the 3000ST stands put neutrality ahead of all else. The support column
Total £724
