Really basic SCART question
Discussion in 'Cables & Switches' started by doctorjuggles, Sep 29, 2004.
  1. doctorjuggles
    doctorjuggles
    Aug 31, 2004
    799
    London
    +19
    Is it easy to remove the SCART head, feed a cable through something and then reattach it? If so, which brands should I buy to make this as easy as possible? (The cheap SCART leads have moulded plastic which doesn't come off.)
    I need this because I'll be mounting my plasma screen on the wall and the SCART lead will be fed through a chrome pipe, which the head won't fit through without dismantling.
    Thank you
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Lektropacks scarts come apart i think IXOS might do too
  3. digisocialist
    digisocialist
    Sep 5, 2004
    480
    Yorkshire
    My TV has x1 SCART, x2 S-Video, x2 Video x3 sets of Audio (Red & White) connections. If I am to connect this to an AV do I use the S-Video and seperate Audio (R&W) leads to connect it up? As I am cabling behind a wall it's proving problematic finding a SCART for this purpose and I believe most AV's don't have a SCART connection anyway.
    So if I go for the following is this the best way?
    http://www.tvcables.co.uk/cgi-bin/tvcables/XHV403-500.html
    http://www.tvcables.co.uk/cgi-bin/tvcables/PGA4205.html
    Thanks in advance
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    ?????? AV what?
