uptown47
Established Member
- Joined
- Oct 18, 2010
- Messages
- 149
- Reaction score
- 13
- Points
- 62
Hi all,
I'm a complete newbie with home theatres (in fact, this is my first). I have the following set up:
Home PC networked over ethernet to a Linkstation Pro.
A WD-TV Live box connected to the linkstation pro.
A Sony STR-2400ES connected to the WD-TV live box (via HDMI).
5.1 Jamo speakers and a Samsung 50" plasma TV connected to the Sony amp.
When I set it all up I was initially impressed with the sound quality (having never experienced 'surround sound' before) but over time it didn't quite seem right. I had set up the Sony by putting that little dongle thing at my sitting position and then playing the 'test sound' but when I played movies and tv programs (via the PC - which is the way we mostly view our media) then we both found it difficult to hear the dialogue. If we turned up the sound to hear the dialogue then the explosions etc were far too loud.
I eventually went into the settings on the amp and manually altered all the db levels of all the speakers to try and route the most volume through the front speakers and less out of the back.
This seemed to help with the dialogue but the 'surround' effect wasn't very good.
I have lived with it like this for about 3 months now but (due to a problem with the WD-TV box locking up sometimes whilst 'paused') I was messing with the settings last night and found a setting on the WD-TV box under audio that was either: Stereo / Digital pass through / Digital pass through with optical.
It was set to 'stereo'. Am I right in thinking that all the things I've been playing up to now have just been stereo sound then and not split into the proper 5.1 channels ??
Assuming that is the case, is it better sound with Digital pass through with or without using an optical lead ?
Also assuming that it needs to be digital pass through, what exactly do I set my Sony to to get the best out of a movie? I press the 'movie' button on the remote and it cycles between settings 'A', 'B' and 'C'. B is the setting that I set up with that little listening device when I first got the amp. But is there a better setting. I've read the instructions a couple of times but (and I really hate to admit this) I'm a bit lost
Different things appear on the front display of the amp when I press the 'movie' button such as "V. MULTI DIM", "C.STEX A", "C.STEX B", "C.STEX C" (I presume these A,B,C are my pre-programmed setups but what's v.multi dim?)
Also, the A.F.D button brings up AFD AUTO, E.SURROUND, MULTI ST.
I'm not sure what that should be set to either??
I'm really sorry for what are undoubtedly ridiculous questions but I would really like someone to help me understand this amp so I can get the best out of my set up.
Many thanks for any help you can give me
John
John
