realistically - can i get a Panasonic 42in Plasma - TH42PWD6BX
Discussion in 'Panasonic TVs Forum' started by lee-s, Oct 19, 2004.
  1. lee-s
    lee-s
    and all the needed extra's (relevant scart convertors / connectors) for under my budget??
    im a total newbie to the world of plasma but am determined to get one asap, i realise theres plenty of threads on here about this screen so my minds pretty much made up on that, but all this talk of youll need this box & this lead etc etc is totally losing me :blush:
    obviously i need to speak to the guys @ AV but can anybody whos just bought a similar set up (completely from scratch) tell me if im going to go way over what i can afford??
    ideally i'd like to keep it as much under £2k as possible, i dont spend hours & days in front of the Tv due to work commitments, but i would like to have a nice big screen indoors when i do. As with most things it seems my initial idea of easily getting something good for around the £1500 mark isnt going to happen (dont really want a Tiny screen)
    all it'll be used for is the odd dvd, possibly some x box action and largely, regular tv use (all be it form crappy analouge NTL cable)
    going on what other topics ive read on here over the last few days i gather this is probably THE most brought up topic for us know nothings so apologies in advance :)
    ANY help or advice will be greatly recieved :lease:
  2. AV Junky
    AV Junky
    Oct 30, 2002
    1,215
    Staffordshire, UK
    +69
    Go to the special offers forum, then follow the link for the PW6 at AV sales. All the prices are there in black and white for you.
  3. Todda
    Todda
    Before you can choose which boards to buy, you will have decide how you want to connect your equipment to the Plasma.
    Take into account that the plamsa already has a 15 pin VGA port on it which means you will be able to either connect from a PC or any equipment with a YPbPr component out.
