Real wood?
Discussion in 'Home Cinema Building DIY' started by davepop, Jan 26, 2005.
  1. davepop
    davepop
    Oct 14, 2002
    49
    On the M1
    Hi. I am going to build a little rack for all my kit. I say little it'll be 1800mm long and 600mm wide. I'll be using real wood that I'll stain and varnish.
    Someone told me I should build it in the room it is going to be in as the wood will warp. I don't really want to do this as I want to take my time and there will be the mess.
    Is it true the wood will warp? If so how can I prevent this.
    Also does staining make it worse?
    Cheers :thumbsup:
  2. johndon
    johndon
    Feb 3, 2002
    1,925
    48
    +88
    Depending on the moisture content, the wood can warp as it dries out - this is why you're often advised to make sure that real wood flooring is kept in the room it's going into for a few days prior to fitting.
    As long as the wood is kept in similar conditions to the room the rack is going into for a few days before you start work, you should be OK.
    HTH
    John
  3. davepop
    davepop
    Oct 14, 2002
    49
    On the M1
    Thanx for that. I'm not quite ready to build it yet. If I get organised I'll post the progress pictures here.
  4. woody67
    woody67
    Nov 11, 2002
    634
    Birmingham, UK
    +13
    It depends on the wood and how the rack will be constructed.
    Some wide unsupported areas of board may warp slightly, but not too much. I don't think there would be too much problem with a typical rack, properly fixed together.
  5. Roguey
    Roguey
    Aug 1, 2004
    203
    +13
    hmm, im not sure on the excult woods name, but i think oak can move upto 30%
