Real wood veneer Audience 42
Discussion in 'Home Cinema Speakers' started by kklee, Aug 11, 2003.
  1. kklee
    kklee
    Hi guys,
    i've got a question about the audience 42.
    is there any difference between the real wood veneer and the vinyl version (apart from the finish)?
    as far as i observed from a local dealer shop, the front buffle of the real wood veneer version appeared to be a little bit thinker and the drivers looked different in color.
    just want to know if there's any difference in performance between these two versions.
    kklee
  2. Nobber22
    Nobber22
    Jun 6, 2002
    2,979
    Berkshire
    +110
    Can't answer for the 42's, but WHF magazine says the real-wood version of the slightly bigger 52's DOES sound a bit better all-round. Apparently the real-wood cabinet is a bit stiffer, so improving the sound. Whether you accept WHF's opinion as useful is up to you. :)
  3. kklee
    kklee
    Thanks for your reply. Nobber.
    However, i am not convinced with WHF's explanation for better sound quality.
    Consider that the finish (no matter real wood veneer or vinyl) is of a thickness about 0.1 mm comparing to 10+ mm of MDF.
    I think the improvement to the build is insignificant.
    Perhaps, a thicker front baffle may be responsible for the difference.
    regards,
    KK lee
  4. Nobber22
    Nobber22
    Jun 6, 2002
    2,979
    Berkshire
    +110
    I disagree. ;) Build and quality of construction material can make a big difference to the sound. A stronger cabinet resists internal vibration better too. I'm not disagreeing about a diff. baffle having no effect either. All-in-all it appears to be a subtle, but (according to WHF) effective update of a fantastic (IMO) speaker range. Looks much nicer than the vinyl finish too. :)
