Quantcast
Real time analyser
pajare
Found a free real time analyser on Allen & Heath website that you could use in your laptop or PC. Would probably be handy for checking basic room response. You will need a mic or a lead to connect from your sound level meter. it is on a 14 day trial but if you want to keep it it only costs £6.25p
at http://www.allen-heath.com/rta.asp
Cheers-----------Pajare
Big Al
Looks intresting. Thanks for the link
Big Al
Supra
I think i will have to download this as soon as I get a BFD.
The specs sound pretty good.
Thanks pajare :thumbsup:
buns
If you want something to set up your BFD, try spectraplus. It is incredibly powerful and the 30 day trial should be plenty enough to get you sorted! :D
ad
avanzato
I don't think 1/3 octave is fine enough to Eq a sub you can easily miss narrow peaks or troughs. I'd say 1/12 is minimum.
Like Buns says get spectra and do it within 30 days as it costs 100's to buy.
