G
Green Man
I'm playing Real audio (.smil files) through Winamp via the Tara plugin. It works perfectly for one of my sound cards but not for the other (RME 9632). I get the following waveOut error message:
"Unsupported PCM format (22050 Hz, 16 bits per sample, 2 channels). Please change format settings in input plug-in configuration or change output device in waveOut plug-in configuration."
Has anyone else had this problem before? Can anyone suggest a way around it? I don't really want to change the sound card settings as I push a lot of other output successfully through it.
(The source is http://www.rte.ie/smiltest/radio_new.smil)
Thanks in anticipation.
