Readynas USB sharing problem
Jazz Monkey Jr
I have a Readynas duo and have connected 2 2TB USB drives to get more storage.
I am using a popcorn hour and can browse network and can access one of them but not the other, it shows up but when I try to access the USB drive it comes up with an error.
I have set both USB the same on the ReadyNAS config but I can't get the Popcorn hour to access it.
Can anybody help :lease:
themediaman
Established Member
might seem obvious, so i apologize if so............
make sure a share is set up in the shares section for the new drive and that all the sharing protocols, CIFS, HTTP, FTP are set to read or read/write......
i only have one drive connected to mine............
Jazz Monkey Jr
I have 2, both are set to share and I can access one from the popcorn hour but not the other which has the movies on it.
themediaman
Established Member
all protocols read/write?
themediaman
Established Member
Dont know what else to try...........
Maybe delete the share, format the drive to EXT3, turn off DLNA server, REBOOT...........
Then start the process again...............
Its strange one USB drive works but this one will not...........
Jazz Monkey Jr
I have sorted it now. :)
There was an index in the root folder from when I used YAMJ on the original NAS and it copied over with the other files so it looks like the index.htm was trying to display but couldn't.
Thanks for all your help. :blush:
themediaman
Established Member
Well spotted.......................well done.........
Amazon Fire TV Cube Gen 3 Review: Coming Soon
