ready for my audition need some tips
Discussion in 'Hi-Fi Stereo Systems & Separates' started by kopite, Apr 11, 2003.
  1. kopite
    kopite
    Sep 27, 2002
    112
    Liverpool
    RIght I`ve got the music together
    I`m taking
    the most relaxoing classical album in the world ever.
    Prodigy - music for the jilted generation
    Our lady peace - Gravity
    Radiohead - Kid A
    White Stripes - Elephant
    REM - AUtomatic for the people
    Flaming Lips - Yoshimi
    Got the players I`m listening to sorted
    NAd 541i
    Arcam 72t
    marantz 6000
    CHose the speakers to hear it through
    Quad 11L`s
    B and W 602`s
    Been informed I`ll be best with analogue coaxial with the receiver I have.
    Now I just want some help in how I should go about it and what I should be listening for most. I`m feeling a bit out of my depth with this
  2. wilber
    wilber
    Sep 29, 2002
    1,970
    +30
    take less & concentrate on a few tracks
    classical, prodigy, rem would be my suggestion
    Basic rule is to only have one variable so if you can get them to connect to your make of amp (or similar) & your make of speakers that will help enormously. If you are changing speakers as well as player then you're in for a very long session - I'd choose the speakers first then choose the cd player.
    Make sure the speakers are set up similarly to how you will have them at home - if they have to go close to a wall make sure that's where they are placed.
    Set the listening level to how you would really listen to it - often things sound "better" 'cos they're a bit louder.
    Try to get down to two players asap and then concentrate on those & when you are down to one suggest taking it home over the weekend - if it's a reputable dealer, this won't be a problem. It's when you get it home that you should ask yourself the question - is this really what I want & if it isn't have the courage to go back and tell them - I did with the ARCAM 72T which though it was a great CD player, didn't do enough for me to justify spending £380 on it (I'm having a Roksan Kandy player this weekend).
    Good luck
  3. shodan
    shodan
    Dec 11, 2001
    9,984
    shoeburyness
    +4,201
    Phone them first to make sure they have all the equipment you want to demo!!! No point in demo-ing half on one day and the rest another!
  4. sounddog
    sounddog
    Dec 11, 2002
    3,353
    107
    Leicestershire, UK
    +449
    I posted my audiotioning comments in your original thread ... not sure if you saw them or not ... sorry was a really long post!!
    Vikki
  5. kopite
    kopite
    Sep 27, 2002
    112
    Liverpool
    I rang them up and they ahve everything in I want to test.
    The thing is My receiver and speaker at the mom are crap but they will be getting updated just a cd player is the most important.
    I think I will go with the quad 11L`s as the speakers and concentrate on the cd player
