Reading SD media cards
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by dunk, Jul 23, 2002.
  1. dunk
    dunk
    Hi, i have a Panasonic NV-MX8B. Is it possible to download information from the SD media card direct from the camcorder instead of removing the card and reading it using the USB card reader?
    Also, can you buy third party versions of the software and drivers needed to connect the camera and the USB media card reader to a computer? I wouldn't ask except that i'm using a Mac, and the only software supplied with the camera is for Windowze :mad:
    Dunk
  2. Mujja
    Mujja
    Jul 27, 2002
    630
    28
    Portsmouth
    +38
    It depends if your able to connect your camera directly to the computer with a USB cable. If you are able to do this then the computer should be able to see your camera as a USB device. Some drivers maybe needed so that it is able to recognise it properly.
    I dont have any experience of MACs. But with my Pana GR-DVP1, WinXP recognises my SD card as a removeable drive and I am able to drag, drop, copy and paste files are if it were a floppy.
    You may need to check the drivers CD (if u have one) or try on find some MAC drivers on the Panasonci site.
    Another place to check for tips is a Mac users site. There might be 3rd party drivers for cameras.
