richjthorpe
Established Member
Hi all,
Does anyone else find when you stop a recording through the menu or delete a record tv programme that it doesn't work the first time ?
For example, deleting a recorded programme, select the program, select to delete then on the delete confirm I need to hold the 'OK' button down for about a second before it will actually delete. Any less or any mroe than a second and it wont take the command.
Anyone else had this ?
Using the standard MCE remote.
Thanks,
Richie.
Thanks,
Richie.
