Re wiring house – what cables?
Discussion in 'Cables & Switches' started by Triggaaar, Apr 23, 2004.
  1. Triggaaar
    Triggaaar
    Apr 13, 2003
    5,494
    +1,012
    I’m in the process of doing a loft conversion. A new central heating system has gone in, and I’d like to take the chance to run cables around the house. My question is, what cables should I run, while I have the chance?
    I would like my system to be:
    Living room: Home Cinema, with Plasma and Sky +
    Under stairs: PC playing DVDs to Plasma, and storing all music
    Several other rooms: Squeezebox or Roku etc, and TVs
    I will always have access to wiring between the living room and under the stairs, but will shortly not be able to run cables around the rest of the house. I will run Cat5 from under the stairs, to all rooms, for any Squeezeboxes and internet requirement.
    I would like to be able to feed my sky signal into my PC, for copying, scaling & de-interlacing. I understand that the PC cards are expensive at the moment, but as I will have access, I can add this functionality when it becomes feasible.
    My questions :)
    For the distributing of sky around the house, should I run Cat5, or std TV coax? Does it depend on whether the signal is straight from sky, or through a PC?
    Are there different qualities of std tv coax available? If so, where can I look?
    Many thanks in advance
  2. fufna
    fufna
    Have a loot at CPC, RS Farnell etc for decent install cabling.
    I'd say run every cable you can.
  3. clockwork
    clockwork
    Oct 13, 2002
    40
    Edinburgh
