Re-setting the Panny PW6 Remote
Discussion in 'Plasma TVs Forum' started by vblue, Dec 16, 2004.
  1. vblue
    vblue
    Was using the remote on my PW6 to check how many hours the screen had been on for, but it now doesn't work, the LED still flashes so it's doing something, just not what I want! :confused:
    Does anyone know how I reset the remote, or re-programme it?
  2. reckless
    reckless
    Dec 21, 2003
    987
    28
    +30
    I'm not an expert but I think I'd take the batteries out and then put them back in.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    ah i think you may have turned IR commends off (why untrained peeps should not be in service menu) Need a dealer with a laptop and RS232 control protocols to reset option IIRC there may be a factory reset for the panel to set to shipping state but dont know what it is...
