Robs Ears
Established Member
Hello again.
Firstly, thanks for all the help and enthusiasm in the initial beer inspired build, it was/is a beast of a thing.
I found that I cant reply to the original thread - Missile nosecone for a sub box? - AVForums.com So Ill try another as I have a problem.
The Mission plate amplifier that I used looks to have died, suspected PSU issue as theres no power light coming on and all connections appear fine.
Do you guys have any advice as to how to check for certain just what has died, or more to the point that the driver is still ok?
Assuming the driver is good, any thoughts on a replacement for the very adjustable Mission plate amp that I used? (It served me well and would be happy to fix it if possible.)
Thanks in advance for any help.
A pic to jog the memory...
