RE:DTS Sound on hitachi Illumina
Discussion in 'General TV Discussions Forum' started by Acolon, Jul 5, 2003.
  1. Acolon
    Acolon
    HI i have a hitachi illumina 43" rear progection t.v and recently tried to put a dts dvd through the scart and when i select dts on the dvd the t.v will not decode it, Do i need an engineer out or is it something simple like do i need a different scart i'm using a gold scart that cost me alot of money. Anyone have any input??
    Many thanks in advance.
  2. nathan_silly
    nathan_silly
    DTS can only be decoded by a DTS processor, usually found in a AV amp, processor or seperates speaker system.
    Plugging the SCART output from a DVD into the TV will only get stereo (can be decoded into Pro-Logic though)
    Does the TV have digital input? (coaxial or optical)
  3. Acolon
    Acolon
    Yes it does have optical and coaxial. Sohould i connect throught that?
  4. Acolon
    Acolon
    The tv has a built in decoder for the dts sound. Sorry.
  5. nathan_silly
    nathan_silly
    Send Component or SCART RGB - (component is video only, SCART RGB is for video & audio-stereo or upto Pro-Logic) and a coaxial or optical from the DVD to the TV for Dolby Digital & DTS decoding (5.1 sound)
  6. Acolon
    Acolon
    So i need to run the coax from the tv to the dvd to get the dts running?
  7. nathan_silly
    nathan_silly
    Yup. And for Dolby Digital.. if the TV decodes that as well. Try using a normal phono for now... and get a 75ohm phono to phono whenever.
  8. Acolon
    Acolon
    Great man thanks!!
  9. Acolon
    Acolon
    Should i use a coaxial or an optical cable for best results??
