Re: DGL-4300 PS3 settings
Discussion in 'Playstation Forums' started by Mr Loaded, Sep 11, 2007.
  1. Mr Loaded
    Mr Loaded
    Mar 24, 2007
    908
    28
    +27
    Hi all
    I am currently connecting my D-Link DGL4300 wireless router which is upstairs to my PS3 which is downstairs.
    I can connect fine and looking in my system settings my signal strength is 80% whch i thought was rather good.
    However whenever i try and download anything from the PS Store it takes ages. I am with Virgin Media with a 20mb connection so i thought i would be able to download items a lot quicker.
    Are there any special setting i need to set my router to etc etc
    Any advice would be gratefully received.
  2. Moogle
    Moogle
    Aug 28, 2005
    13,751
    London
    +1,398
    Downloads on the PSN have a tendency to be pretty slow and seems to be the case for pretty much everyone. I dubt it has anything to do with your connection or router or that there is anything you can do about it. Even though your connection might be fast Son'y online infrastructure is not really that effecient when it comes to downloads.
  3. Jim_Fear
    Jim_Fear
    May 17, 2005
    1,801
    Caterham
    +59
    I have the same router, is gamefuel turned on? This is basically bandwidth priority throttling, try it again with the opposite of what you have it set to at the moment :D
  4. colonelblighty
    colonelblighty
    Sep 13, 2005
    3,994
    somewhere
    +693
    Hi, I have the same router and I was well hacked off with the PS3 poor wireless download speeds so I invested in some homepugs and have never looked back
