FunkyMonkey
Established Member
Will re-decorate soon. My wires are taped to the skirting with thick white tape which does a half-decent job of hiding them. However, I want to enbed them into the walls before redecorating. Can you channel wires horizontally, or will you come up against an obstruction, like a batton that holds plasterboard to the back wall surface?
Another thing, is there a light-ish, neutral colour that I can use to paint hte wall which is boring magnolia at the moment, that is also good for reducing reflections from TV (and eventually as possible projector) when the lights are dimmed?
Thanks.
Thanks.
