RE:Colour Movies>Black+White
Discussion in 'Projectors, Screens & Video Processors' started by butch9850, Nov 26, 2004.
  1. butch9850
    butch9850
    Lets just say,you wanted an old style affect,black+white...from a colour movie.
    On a normal tv,you would turn the picture colour,down to 0.
    Now on a projector..what happens?.It's impossible?.
    Some colour movies i would love to see in black/white..Like Shawshank Redemption.
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    It really all depends on the make/model. Many projectors do have controls which are very similar to a normal TV, but I can't say that they all have.
  3. red16v
    red16v
    Aug 20, 2004
    552
    +5
    I'm not familiar with these sorts of displays but I am familiar with tv signals ! I'm assuming your tv projector if fed from a dvd ? if that's the case the connection between the two MAY be component yuv (sometimes labelled yPbPr or YCbCR) - simply pull out the uv or PbPr or CbCr cables between the two and you will have disconnected the colour information between the two. The above 'trick' will not work if the interconnection is RGB. Regards, yt.
  4. Tempest
    Tempest
    Jan 11, 2002
    7,045
    Horley, Surrey
    +2,260
    Probably the best way would be to go down to PC world, to where they have the projectors on sale and ask if they can supply a black and white screen for the job.
    Believe me, I'll bet they go and check for you
    :D
