RDXS34 RGB loopthough?
S
Steve Church
Does the RDXS34 loop through the RGB signals from its scart i/p socket to the scart o/p when the recorder is in standby. My Freeview box only has one scart o/p which I need to go to the recorder and the TV.
S
Steve Church
I've just spoken to Toshiba who says it is not possible to loop through with the unit in standby. Is it feasible to split the rgb signals from the Freeview box?
S
sinclair
I've got Sky and though the XS34 is generally powered up when we're watching, it does loop through RGB when in standby as long as the Satmon button has been pressed. Maybe Freeview is different although I'd be surprised.
S
Steve Church
Aha, not found that button yet. Will check it out when I get home.
S
Steve Church
Ok, found the button. Problem solved, although the manual doesn't explicitly say this feeds the signal to the o/p socket.
Trending threads
