RDXS32 has anyone used reasonably priced dvdrs.
Discussion in 'Blu-ray & DVD Players & Recorders' started by killain, Nov 2, 2004.
  1. killain
    killain
    hi, can anyone tell me if they have successfully used so called cheaper brands in their machines?
    brands such as the new g05 dye discs which you can pick up for 30p each or less.
  2. davet010
    davet010
    Jul 23, 2004
    385
    +10
    Bought 100 Bulkpaq 8x (Verbatim dye) from mfym.co.uk for £24, and not had a coaster yet out of them.
    Doesn't seem to like my Rytek 8x disks, however.
  3. Neville Street
    Neville Street
    Jul 11, 2004
    290
    +4
    Datawrite Greys 8x from svp £5.99 for 25. No coasters at 10 used. Tested in various other players (mine/friends/portables/pc).
  4. killain
    killain
    thanks for the input. much appreciated. :)
  5. Stanman
    Stanman
    Feb 7, 2004
    1,550
    +156
    I've burnt 6 bulkpaq oranges without a coaster apart from one which has a smudge mark on it and the machine did not like it.
