RDXS32, ERR-14 code on front, what next guys ?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Taz69, Mar 23, 2006.
  1. Taz69
    Taz69
    Apr 15, 2002
    3,483
    Bristol
    +357
    Hi all, last night I copied the Liverpool footie match from Sky + to my RDXS32 so I could put it onto dvdr for me to keep, (its not everyday your team wins 7-0 is it now) :clap: anyway I then put a ritek blank in the drive to sopy it over and when it started writing it came up with a error on screen something like cannot write to disk - writing error or similar, also on the LCD display there is an error message ERR-14 I unplugged the recorder overnight to see if that will clear it but no, its still there.
    I think it may be under warranty from JL still, not sure, but if I do send it back will they wipe the HD as I have stuff on there such as the match above.
    Thanks in advance
    Mark
  2. captaindobie
    captaindobie
    Apr 17, 2002
    592
    Scotland
    +21
    I have the RDXS34. Err14 = ''DVD disc access error detected'
    To remove this message from the Tosh display - press the 'display' button on the remote.
    Hope this helps...
  3. Taz69
    Taz69
    Apr 15, 2002
    3,483
    Bristol
    +357
    Thanks m8, that cleared the error message, :thumbsup: I have now put anothyer blank in and will see what happens, so far its at 10% so it looks like a faulty disk. :clap:
    Mark
  4. Churnobyl
    Churnobyl
    Sep 22, 2005
    219
    swansea
    +5
    its when you get err 7061 is the time to worry. then your toshiba will be ready for the bin.
