RDXS32 DVD-RAM formatting problems.
Discussion in 'Blu-ray & DVD Players & Recorders' started by dvbdvb, Jan 12, 2005.
  1. dvbdvb
    dvbdvb
    I don't expect a solution to this however this message is posted for awareness of a potential issue with the RDXS32 and DVD-RAM.
    I've had problems in two areas using the supplied Toshiba DVD-RAM disc (type 2 singled sided). The disc is in brand new condition and not dirty at all.
    The first problem is that timer recording to DVD-RAM does not work. The message "an unexpected error has occured" appears on the screen & then recording does not commence. Manually activating recording to the same disc works fine.
    Secondly, executing "DVD-RAM physical format" from the setup screen does not work. It churns away for about an hour and then says "This disc can not be formatted". Subsequently the DVD-RAM disc is unusable. It can not be "logically formatted" (from the quick menu) & is not recognised by the machine afterwards. There is some ambiguous mumbo-jumbo in the manual that fluffs over whether physical format of DVD-RAM will work or not. I just tried it out to see if it made any difference to the timer recording problem.
    My machine has the ZL10/1414 firmware.
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,710
    Warwick
    +2,585
    How old is your Toshiba RDXS32 - do you have any problems with any other types of optical media? I have come across a similar problem on an old HS2 - the optical head developed a fault which caused read/write errors.
    I suggest trying a different brand of DVD-RAMs - Panasonic for example - if the problem persists then seek a repair on the Toshiba. If not just put it down to a dodgy disc.
  3. dvbdvb
    dvbdvb
    The machine was bought not long after they became available in the UK from Empire Direct in September. It has been fine with -R,-RW.
  4. ManojD
    ManojD
    I also have similar kind of problem with my DVD Recorder RDXS32 that I bought in July, 2004 at Richer Sounds, Blackfriars.
    It does not format RAM discs. I tried 4 discs .... one supplied with the DVD Recorder, two Panasonic and one Maxell.
    I came to know about this very recently. My mistake was to assume that everything would be fine and also I would never use RAM discs as they were/are costly. So never tested the RAM discs during the guaranty/warranty period. I am moving to India now, where, I guess, Toshiba do not sell these units.
    Still I am happy with this otherwise a very fine machine.
    Manoj.
  5. TVHEAD
    TVHEAD
    Nov 29, 2004
    59
    11
    Can anyone reading this point me to the link for the firmware upgradefor the RDXS32 , I lost the link for this upgrade, beleive it was on the Toshiba site in Germany, and is ment to improve media compatibility, Thanks.
  6. ManojD
    ManojD
  7. TVHEAD
    TVHEAD
    Nov 29, 2004
    59
    11
    Thankyou Manoj.
    Now to try annd install this update.
    :smashin:
