RDXS32 And Sat monitor
Discussion in 'Blu-ray & DVD Players & Recorders' started by mr digital, Dec 4, 2004.
  1. mr digital
    mr digital
    Hi all, thanks to those who have helped me out with previous issues on this recorder.
    Now that i have the code to enable the recorder to change my satellite channels, i cannot find the PDC option in the quick menu once i have entered a video plus code.
    Is this just one of those things or can this still be done.
    Thanks. :lease:
  2. tobyjuggler
    tobyjuggler
    Nov 4, 2004
    629
    I don't believe Sky carries PDC.
  3. mr digital
    mr digital
    Possibly this is correct. However if i just select the required channel for recording as AV2, & not input it as the actual 3 digit Sky channel it the option for PDC then appears in the quick menu.
