Thanks very much for you help.
I have now completed all the connections as you described and my HXD-870 has now picked up all the terrestrial channels.
I still have a problem with it tuning to my eurovox decoder. It seems to find a signal from this source but it does not recognise the channel being changed but stays tuned to a sky sports channel. Any help on this issue much appreciated.
I don't know much about the EuroVox decoder other than what I have just had a quick "google" at.
But it appears to be a cable TV "converter box" is that correct?
If so does it output each of the cable TV channels on their own UHF carrier such that you would have to tune in the Analogue side of the HXD-870 to receive each channel? If so connection and tuning seem quite easy.
Or do you select the channel that you want to watch on the EuroVox box and then the HXD-870 should automatically select the input source?
If so then:
Looking in the manual at page 33 it shows an "external decoder" connected to the HXD-870 via SCART however the key point of the setup is that L1 is now set to "decoder" and then at points 12/13/14/15/16/17/18/19 on page 35 you appear to have to do another Analogue Scan.
It also looks like in the Guide + you at point 8 on page 29 have also to set the brand of receiver in this case EuroVox or ????
You also appear to have to use the "set top box controller" located close to the senser on the external decoder. Info on this is again on page 29. Bottom Right Hand Corner.
But the key point appears to be if an external decoder is to correctly interwork with the HXD-870 then the channel numbers on the external box HAVE TO correspond to the same channels numbers on the HXD-870 for the same program i.e BBC1 on channel 1 on both devices.
So that when you select a program on the external box using the external box handheld remote, the HXD-870 also sees the command from the external box handheld remote and at the same time switches the HXD-870 to its "decoder" port.
If it don't work anything like that but just like an external "freeview box" then it looks like you should set the SCART to L1 and then select L1 on the HXD-870 and the program that you want to watch/record on the external decoder.
I hope what I have written is helpful but I have never set one of these up before....sorry.
