Rdr-hxd970
Gavtech
Administrator
No. Such possibilities are usually specifically disabled by the big-name makers.
bradavon78
I'd imagine you can connect it using a PC Video capture card. Whereby it records the video coming in instead of a native Freeview stream.
It's not something that the Recorder is designed "with it in mind" though.
ramjet
I suspect he wanted to stream it to a pc using usb or ethernet or similar , to transfer recordings etc
so no it cannot be done
you could use a video capture card and record composite or rf depending on the card used , or use a dazzle or an easycap or some such similar usb adapter to send recordings to the pc ( composite to usb )
but its simpler to burn direct to dvd-rw and then load into a pc from its dvd reader/writer
