RD50 broken i think :(
Discussion in 'TVs' started by locky79, Aug 13, 2005.
  1. locky79
    locky79
    Aug 27, 2004
    530
    +8
    Hello
    well ive had my RD50 for about8 8 months now and ermmm ive just had a slight problem.
    basically the colour went funny and then went black and then when i try to turn it on it comes with a double red LED.
    since the manual is totally rubbish i have no clues to whats wrong with it :( pleases someone help me quick!
    RAZOR!
  2. locky79
    locky79
    Aug 27, 2004
    530
    +8
    ps i just noticed its the light next to the power standby light :\ and theres a bulb symbol...
    but theres no way it could have blown as i havent used more than the estimated lamp life!
    anyone tell me about my warrenty and bulb stuff :\ please say i dont have to buy another one do i?
    any help?
  3. Razor
    Razor
    Dec 15, 2004
    37,552
    2
    +12,510
    Locky give Optoma bell as you have a 2 year warrenty
  4. locky79
    locky79
    Aug 27, 2004
    530
    +8
    i havent even used it that much :( and it died already!
    i had a shuttle pc connected to it and i was watching something on it :( i had it on 60hz but still cant believe its died already
    oh :( hows your hanging? and has anyone elses bulb died or am i the first victim?
  5. locky79
    locky79
    Aug 27, 2004
    530
    +8
    argh! i just called optoma about the lamp and she said its 3 month warrenty on the lamp :eek: then i said to her its 1 year but shes gonna call and double check :rolleyes:
    im very sure its 1 year right? or am i going CRAZY! :lesson:
  6. locky79
    locky79
    Aug 27, 2004
    530
    +8
    update!
    well she called me (very lovely voice she has too :D ) and said she would arrange a courier to send a replacement bulb and also to collect the faulty one :D
    felt a bit funny taking out the bulb but i got it out and cant see any fault with it anyone want some pictures of it? its like a Fog lamp on a car :> but a mini version :)
    woot!
    ps Customer Service rating 9 :) i have to replace the bulb myself but its not hard at all :)
  7. locky79
    locky79
    Aug 27, 2004
    530
    +8
    ok update :\ ive changed the bulb and same problem! arrghhh i dont know whats wrong with it :(
    any ideas what red standby light and red lamp light means?
  8. Van300
    Van300
    Jan 3, 2005
    182
    Derby, UK
    +11
    The manual suggests lamp failure.
    The american manual also indicates that a blinking red light, as oppose to a constant red light, on the bulb symbol would be an internal fault other than the bulb.
    It sounds like you need Optoma to send an engineer.
    I hope you get it sorted.
  9. Razor
    Razor
    Dec 15, 2004
    37,552
    2
    +12,510
    Sorry to hear your having a bad time Locky. :(
  10. locky79
    locky79
    Aug 27, 2004
    530
    +8
    well i called them today since i had no reply from my email and they are going to send a engineer out but im not sure when that will be but i have left them my email address and mobile number so they can tell me when hes or SHE is coming ;) i hope ShES a hot sexy engineer :clap: :clap: :clap: i want to see those butt cheeks :D
  11. locky79
    locky79
    Aug 27, 2004
    530
    +8
    ok engineer came over to my house today and we changed a few curcuit boards but no luck :( which can only be the lamp board section which optoma will have to send him the parts to install on my tv ;/
    well the engineer guy was great :) hopefully see him next week :)
    YAH
  12. Razor
    Razor
    Dec 15, 2004
    37,552
    2
    +12,510
    Your set has been out of action for a while now. You have my sympathies. :(
  13. locky79
    locky79
    Aug 27, 2004
    530
    +8
    on a side note, the engineer said mines the worst one hes had to fix
    :D :D :D
  14. Razor
    Razor
    Dec 15, 2004
    37,552
    2
    +12,510
    Can you not insist on a replacement? :confused:
  15. locky79
    locky79
    Aug 27, 2004
    530
    +8
    ok i got no reply from optoma or the engineer this week and im starting to lose patience now.
    i think my tv has been out of order for 3 weeks now! is it me or do i have to call them every day until this is sorted out?
    also i noticed when the engineer couldnt repair the tv when he replace 3 PCB boards when it says machine on contract, warrenty, repeat call and chargeable
    chargeable was ticked! so im thinking am i gonna get charged for this? because if i am im sending the bill straight to optoma. :mad:
    GRrrr how many days do i get before i can insist on a total replacement?
    pleases Helps!
    GRRRR!!
  16. Chumpy
    Chumpy
    3 reasonable attempts to fix I believe - but I would be calling them each day until they get someone to fix it. Hope it get sorted soon.
  17. big ric
    big ric
    Just wondered if you have got your problem sorted yet as i brought my RD50 just before you got yours and i'm getting paranoid about mine breaking down
