RCE Questions
Discussion in 'Blu-ray & DVD Players & Recorders' started by GidGrace, Jan 17, 2001.
  1. GidGrace
    GidGrace
    I have a few questions about RCE which I would be grateful for help with...
    How can you tell if a disk is RCE protected?
    Is there any way to get around it? e.g. hack / chipping
    How can I tell if my player (Panasonic A360) will play RCE disks without (potentially) wasting £18 or so on an RCE disk?
    The reason I am so confused now, is that I have read a few posts about RCE and thought that the Hollow Man disk was RCE (I had already ordered this from DVDBoxOffice in Canada), when it arrived I was expecting disappointment, but the disk played fine. My player is multi-region but I can play either R1 or R2 disks without having to change any settings.
    Thanks in advance,
    Gid
  2. GidGrace
    GidGrace
    I guess I found the answers to my own questions. The site I found has some great info on RCE and lists compatible modified players and workarounds for those modified players which will need further coaxing to play RCE.
    http://www.dvdlibrary.co.uk/technical_page.htm
    If you're as confused as I was earlier today, check it out!
    Gid
