RCE Question
Discussion in 'Blu-ray & DVD Players & Recorders' started by Atari, Mar 20, 2003.
  1. Atari
    Atari
    Dec 11, 2002
    32
    The Netherlands
    I am intreseted in buying the R1 superbit version of Das Boot and The Fifth Element , but not sure if the RCE protection is a problem for many DVD players. I also heard that there was a new version of RCE out has anyone come across it.
    I have a multi-region Toshiba SD220. Would I have any problems playing R1 superbit titles.
    many thanks
    Atari
  2. bobbles
    bobbles
    it shouldn't have any problems
    it tends to be the remote hacked players that have problems with RCE
  3. Atari
    Atari
    Dec 11, 2002
    32
    The Netherlands
    Bobbles
    Many thanks for your help.
    Have a great weekend.
    Regards
    Atari
  4. stevelup
    stevelup
    Aug 13, 2002
    6,508
    Swindon
    +1,080
    I can confirm that a hacked SD-220 has no problems with RCE.
    Steve
  5. Atari
    Atari
    Dec 11, 2002
    32
    The Netherlands
    Steve
    Many thanks for the confirmation. I have just received "Fifth Element" Superbit R1 RCE and my DVD player has no problems.
    Atari
  6. activeservo
    activeservo
    What exactly is "superbit"?????.As you stated superbit version of Das Boot.What does this mean??????? Thanks in advance.:smoke:
  7. stevelup
    stevelup
    Aug 13, 2002
    6,508
    Swindon
    +1,080
    Superbit DVD's use the maximum amount of space on the disc purely for the audio and video of the main feature. Extras (if there are any) are on a seperate disc.
    They usually include a high bitrate DTS track as well.
    Steve
  8. ferris57
    ferris57
    Jan 18, 2003
    874
    "According to Columbia Tristar, by reallocating space on the disc normally used for value-added content (like director's commentaries, documentaries and the like) and multiple audio streams, Superbit DVDs can be encoded at double their normal bit rate while offering full compatibility with the existing DVD Video format. The result is picture quality that provides outstanding detail which complements the performance of the latest progressive scan DVD Video players."
    Although it is meant to be superior on all dvd players.
