N
neo261104
Does anyone know how to hack a Samsung HR735 so it will be able to play reagion 1 RCE protected DVDs??????????????????????
I did a Google and found this on Videohelp.com:-
Region code hack posted by Craig Waugh, January 08 2007:
This worked on my Samsung DVD-HR737
Region 2 purchased in Germany
** Everything should be input from the remote **
1. Power on the player with no disc in the tray
2. Press the DVD button
3. Press the number 0 five times
4. Press the Repeat button (NOT Repeat A-B)
5. Enter the numbers 5 7 5 3 8 quickly
The current region code should be displayed in the upper left corner
6. Press the number 9 for region free (multi-region)
7. Open the tray and close it again
Hope this helps
Kintara![]()
