RCE DVD's
Discussion in 'TAG McLaren Audio Owners' Forum' started by Burgy100, Dec 6, 2004.
  1. Burgy100
    Burgy100
    Apr 20, 2004
    137
    Bedfordshire, England
    Hi Folks,
    The question is simple. Thnking of buying RCE disc, will my multiregion 32FLR play it ?
    Steve
  2. lovegroova
    lovegroova
    Jul 15, 2002
    2,729
    103
    Herts
    +387
    Yes, but you will need to set the region of the player to the specific region before playing it.
    What most of us do to make the player multi region is to set the region to 'Region 0' by doing the following.
    No disc in the player with the door closed and type 7340
    To set the region to region 1: No disc in the player with the door closed and type 7341
    When you've finished with the RCE disc, just the the region back to 0 again.
  3. Burgy100
    Burgy100
    Apr 20, 2004
    137
    I knew somebody would have the answer. Many Thanks Steve
  4. Dick Sternum
    Dick Sternum
    Sep 18, 2004
    63
    Leicester
    +3
    Is the 32FLR different to the 32R for this? I've just got my 32R set to region 0 and it plays RCE disks with no problems!
  5. cskates
    cskates
    Jul 5, 2001
    151
    Belfast, UK
    My FLR has been set to region 0 since I bought it and I haven't had to change for RCE disks or any others (>500 DVDs).
  6. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    Set it to region "0" and simply forget it, as it plays everything known, never had a reject on RCE or region coding (1000+ disks).....
  7. Kenny Glasgow
    Kenny Glasgow
    Apr 1, 2004
    3,350
    Livingston, Scotland
    +227
    Just for info, a lot of R2 discs are RCE
  8. nsfehler
    nsfehler
    Here we go....nieve as ever....
    What's RCE? :blush: :blush:
    Nigel
  9. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
  10. nsfehler
    nsfehler
    Thank you Graham...
    I had seen this before but not recognised it abbreviated to RCE. Thanks for the link - it explains it all well.
    Regards
    Nigel
  11. Dick Sternum
    Dick Sternum
    Sep 18, 2004
    63
    Leicester
    +3
    As a side note - anyone actually hear of a player that doesn't play RCE discs? Even our 1st generation Denon DVD 3000 does!
  12. AMCross
    AMCross
    Dec 3, 2003
    6,023
    Livingston,Scotland
    +208
    My SONY DVP 7700 does not play RCE discs :mad:
    The first problem disc i came across was Bad Boys 2
    Would not play but the wife tells me that's no big shame :rotfl:
