RCE Disks
Discussion in 'Blu-ray & DVD Players & Recorders' started by gizmo_the_cat, Jun 12, 2001.
  1. gizmo_the_cat
    gizmo_the_cat
    I have a multi region Pioneer 515 sourced from China or somewhere. So far it plays everything i have tried. Even the RCE Crouching tiger.. Region 1 disc.
    Is this the case for all players or does RCE really work?
  2. Family Guy
    Family Guy
    There's a lot of confusion over Crouching Tiger being RCE or not. It was originaly posted as being RCE but lot's of people seem to be able to play it on players that previously couldn't play RCE discs.
    Try The Patriot R1. This is definetly R1 RCE and if your player has a problem then this is one disc it definetly will not play.
    Others include Hollow Man & Charlies Angels, both R1 of course.
    Mind you Charlies Angels is the only film that has made me wish my player couldn't play RCE discs!!
  3. Guest
    thought i would just confirm to you that crouching tiger, hidden dragon is not rce. I have it, and it works fine on my toshiba which wont run charlies angels
  4. gizmo_the_cat
    gizmo_the_cat
    thanks Army bloke only one problem - don't really fancy charlies angels or the patriot etc. I will just wait and see what other rce disks come out soon
