RCE disccs and the Tosh SD2109?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Jase, Sep 30, 2001.
  1. Jase
    Jase
    Mar 16, 2001
    10,828
    United Kingdom
    +2,723
    I have the same problem with my Toshiba 210E, via the hack it´ll play RCE but wont access the special features.
    I´m not overly fussed about special features as i´d rather have better quality video & audio (like the new superbit titles).
    I dont think there is a way round it, but i´m sure someone else could confirm this.
    cheers
  2. Guest
    Hi guys,
    there is indeed a way around this problem allowing access to the extras but it requires a bit of experimentation to find the extra that you want (this works for the 2109 definately.<br />Iv'e started with the hack you probably already know for playing the discs for clarity:
    1. Put in the disc. <br />2. You'll see the RCE warning sign, a world map <br />3. Press MEMORY on the remote control. <br />4. Press 01 in the Title Box. <br />5. Press 00 in the Chapter Box. <br />6. Press ENTER Note: The DVD will play the movie, but MENU will not take you back to th RCE warning screen again.
    By Experimenting with title 2 and chapter 1 etc will get you the special features.
    Hope this helps.
    [ 30-09-2001: Message edited by: Skippi ]</p>
  3. Force Field
    Force Field
    Muchas gracias amigos. I will try this.
  4. Force Field
    Force Field
    My dvd player is the Tosh SD2109 which was bought from Link online a couple of years ago, pre-chipped to play R1 discs. With the advent of RCE, I am aware of the hack which allows you play the film on a RCE disc, but it does not seem to allow you access to any bonus features on the disc. Before this week, the only RCE disc which I had purchased was The Patriot, but I have just bought A Knight's Tale, blissfully unaware that it also was RCE. Again, I can play the movie using the usual hack, but whilst I can move around the bonus feature menus, I can not actually get any of them to play. Does anyone know if I can actually access these features using this dvd player, and if so how? Help guys! <img src="confused.gif" border="0">
