RCE Compatability - A Good test?
Discussion in 'Movie Forum' started by andy76, Dec 8, 2003.
  1. andy76
    andy76
    May seem an odd question but what disc would anyone suggest as a good test to a players ability to play RCE discs?
    I have just bought a new Multi Region player and want to check it works OK. Not had any R1 DVDs before!
    Andrew
  2. Drunken Master
    Drunken Master
    May 12, 2001
    836
    In the middle of a roundabout
    +7
    Charlies Angels, locked on my machine. I had to reset the engineers menu!
  3. figrin_dan
    figrin_dan
    Jan 9, 2003
    1,993
    +136
    TriStar and Universal discs. Put in a R2 first, then try the R1, if it fails, try a normal R1, then the RCE.
  4. FoxyMulder
    FoxyMulder
    And if it fails just select a chapter usually 01 and it should play the film even though its regionally coded, anyways if it can't play the film the region code menu pops up and tells u but its easily broken and u can do it without modifying ur machine.
  5. Lux
    Lux
    Nov 10, 2002
    759
    Luxembourg
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    MEN in Black 1 or 2 also any disney disc!
  7. Lux
    Lux
    Nov 10, 2002
    759
    Luxembourg
    disneys don't really test for RCE but how many violations of the DVD authoring your player tolerates before crashing.
  8. Roughneck1
    Roughneck1
    Patriot....
  9. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    12,812
    Somewhere in South Yorkshire
    +5,021
    Spiderman.
  10. Lux
    Lux
    Nov 10, 2002
    759
    Luxembourg
    I just remembered: Sony introduced a new version of RCE with Spiderman. some players that never had problems with RCE couldn't play the RCE discs following Spiderman. so it might be best to get one of the new ones (ie anything after spiderman), like Bad boys 2
    HTH
  11. DaveP
    DaveP
    Was this Region 1 or 2?
    Dave
  12. DaveP
    DaveP
    Or both???????????
  13. andy76
    andy76
    Thanks for the replies and suggestions.
    I wanted bad Boys II so just bought that and good news it works:smashin:
    Problem is now I have a multi region player I will start buying way too many discs:laugh:
    Andrew
