RCE clearing
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by MikeNolan, Oct 22, 2005.
  1. MikeNolan
    MikeNolan
    Nov 28, 2004
    540
    Hereford
    I'm getting a Denon 1920 soon, and the shop I'm buying it from will make it a multi-region unit. Does anyone know if the hack used will also clear the way for using RCE encoded discs or does something else need doing. Those in the shop have not heard of RCE. Thanks
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,833
    Somewhere in South Yorkshire
    +6,469
    Probably. RCE is quite old and most (or all?) new machines, deregioned, will cope with Region 1 RCE perfectly well.
    FWIW, my Pioneer 737 (several years old), Pioneer 520 (almost new), Panasonic L50 portable, and my friend's Denon 2900, all supplied region free, all play R1 RCE without issue.
  3. Justin@UH
    [email protected]
    Feb 21, 2002
    2,194
    63
    Location location location
    +94
    Yes, if supplied via a Denon authorised dealer the mod is RCE compatible.
