RCE Chip for Tosh SD2109
Discussion in 'Blu-ray & DVD Players & Recorders' started by neilbutler, Jun 27, 2001.
  1. neilbutler
    neilbutler
    Jun 27, 2001
    26
    4
    UK
    Got one of these Chipped for Multi Region, but can't play RCE DVD's does anyone know of a Kit to RCE enable it other than the rather costly one from Techtronics? Oh and I don't really want to have to swap disk around either!! :p
    Cheers in advance
  2. spenceruk
    spenceruk
    Depending on the chipping method, it's worth trying the handset hack at www.multiregionmagic.co.uk/rce. Basically, put the disc in and wait for the World Map to come up. Then:
    1. Press MEMORY
    2. Select TITLE 1, CHAPTER 1
    3. Press PLAY, & then CLEAR
    The film should now play.
    A bit fiddly, I know, but not as expensive as a new chip or even a new machine!
    Hope this helps.
