RCE (again)
Discussion in 'Blu-ray & DVD Players & Recorders' started by spenceruk, May 24, 2001.
  1. spenceruk
    spenceruk
    I have a multi-region Toshiba 2109 and I found I could play "Charlie's Angels" with a handset hack found on the Techtronics website. It was a bit fiddly (having to enter Title and Chapter numbers) but it worked fine on that disc and I could access all the special features once I had discovered the Title and Chapter numbers of each special feature.
    Having just received "The 6th Day" I can access the film (by playing it from Title 1 and Chapter 1) but some of the special features are inaccessible in this way and, more frustratingly, I can't access the audio options to alter the default setting of Pro-Logic to 5.1!
    Looks like RCE strikes again!
  2. andyh41
    andyh41
    Dec 28, 2000
    249
    East Grinstead
    +3
    I used the same hack to view Charlies Angels on my SD200. I used the audio change button to cycle through the options to output 5.1. Presumably you can do the same for the 6th day?
  3. spenceruk
    spenceruk
    No, sorry, it wouldn't let me!! Default setting for Charlie's Angels was Pro-Logic and I was eventually able to get into the audio options menu to change it. I have tried and tried to do the same with The 6th Day but to no avail.
