RCA via RG6 vs s-video via Cat5e
Discussion in 'Cables & Switches' started by TonyRess, Nov 29, 2004.
  1. TonyRess
    TonyRess
    I need to send a video feed to 2 locations. Location 1 is 65 feet away from the source and location 2 is 125 feet away from source. What is the best option for the wiring? RCA via RG6 or s-video over Cat5e?
    Any advise would be greatly appreciated. :lease:
    Tony
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    thats a long run mate Cat5 propably best bet have a look at KAT5 gear and Channel plus kit
  3. lucidnightmares
    lucidnightmares
    Well RCA and RG6 are both analog, and if you go the fully analog route I would use RG59 instead of RG6 I like it best. However, coax can get lossy at such a long distance (100 ft. +) Ideally though, s-video will give you a better picture and it is considered digital. I don't know how much loss you will get with the CAT5 but it is your best bet!
    Good Luck!
    Jon
  4. Knightshade
    Knightshade
    Aug 6, 2004
    1,971
    +43
    Cat5 in it's 'Raw' state is designed to carry data packets over a 100metre distance with no loss. It gets a bit flaky above that distance without a repeater.
  5. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,054
    The Borders
    +2,523
    Hello Tony
    Two questions in one I guess!
    Given decent signal transmission then Y/C (S-Video) is going to be better than CVBS (Composite).
    You can do what you require with Y/C as follows:
    1 x S-Video Input cable (4 Pin mini din)
    1 x Kramer VM-9YV 1:2 Distribution amp with line driver (up to 300m)
    1 x 20m VanDamme S-Video cable to location 01.
    2 x 40m VanDamme 75 BNC to BNC cable to location 02.
    1 x VanDamme 2BNC(F) to S-Video adapter (at location 02)
    The Kramer amp has adjustable pots to enable you to compensate for the long cable runs.
    Best regards
    Joe
