rca to bnc advice please
Discussion in 'Cables & Switches' started by mark h, Jul 11, 2005.
  1. mark h
    mark h
    Jul 11, 2005
    3
    Coventry
    I am setting up a new system which includes a 42" panasonic plasma display. After installing the terminal board i have found out that my rca component lead needs to have bnc connections for the plasma. I have found some adaptors on the internet for a couple of quid each, but I do not want to compromise the quality of my new plasma and £60+ component lead by using a £2 adaptor.
    What should I do? Try the adaptors, buy another lead or snip off the rca connectors and buy some decent bnc plugs which I am sure are out there somewhere? If the last option is this simple to do?
    Many Thanks :thumbsup:
    Panasonic TH42 PWD7B,Panasonic DMR-E55,Denon 2803,KEF Eggs,REL Quake,Sky Digi Box
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,312
    Rainham Essex
    +2,425
    It would (at least in theory) be better to have a component lead with the BNC plugs on. In my experience though I found the converters to work well. For only a couple of quid you may as well try them and see what you think.
    I would not recommend a DIY replacement of the plugs as the quality of the joint between cable and plug is critical for a good picture.
    Mark.
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,573
    The Borders
    +3,029
    Mark H
    If its all NEW wont your dealer swap the YUV Cable or the terminal Board so you don't require to use adapters?
    Best regards
    Joe
  4. BDCSTENG GARETH
    BDCSTENG GARETH
    Jul 5, 2005
    347
    Sutton, Surrey
    +8
    In my experience (and I use such adapters on a daily basis in the broadcast world), You will be fine with phono-BNC adapters.
    I will second what Mark said regarding replacing the phonos for BNCs because you will need the correct plug for the cable, and the correct tool to crimp the plug! If you bodge the plug, you will alter the impedance of the whole cable. This will then start to affect signal integrity.
    Regards,
    Gareth
