RCA - Speaker out connection
Discussion in 'Cables & Switches' started by bob_bob, May 27, 2005.
  1. bob_bob
    bob_bob
    Dear All,
    My Sony AV receiver naturally assumes that I will channel all my audio through it's various speaker outs.
    As a result it only provides a video component out to link to my TV and no audio out.
    This seems a bit of a waste of the speakers in my TV and I would like to use them.
    I would like to link my centre speaker outs from the receiver to the RCA audio in on my TV.
    What I want to know is, if I strip the receiver end of my RCA cable can I isolate two separated wires which I could attach to the speaker out terminals?
    Perhaps more importantly, if I do this will I knacker any of my components?
    Thanks all,
    Bob
  2. vizslaraner
    vizslaraner
    Dec 13, 2003
    487
    Hereford
    Methinks a few component names and model numbers might be of assistance here.
  3. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Does your receiver have any pre-outs?
    If you have a dedicated center speaker you may want to stick with that, most TV speakers sound awful.
    Do NOT do this - the speaker out from your receiver is amplified (high-level), the RCA input is low-level, and damage will most likely occur if you make a connection as described.
    As explained, most likely yes. However if you have a preout for the center channel you can connect that to the RCA input at the TV. If there is a stereo input at the TV use a splitter / Y-cable.
    If you need further advise please state the make and model of TV and receiver.
