RCA Socket damaged - *HELP*
Discussion in 'AV Receivers & Amplifiers' started by ReVeReNcE, Apr 16, 2005.
  1. ReVeReNcE
    ReVeReNcE
    Due to an excessively tight phono lead one of the sockets on my audiolab has been damaged. The earth plate around the outside has come off and I don't really want to pay £35 to replace the whole block. Is there any way I can just fix on another earth connection? Picture below! Cheers
    [​IMG]
  2. Cliff
    Cliff
    Mar 17, 2001
    5,832
    167
    Kent & overseas
    +3,141
    I could not see your picture.
    The left and right earths are the same- so you will probably be earthed indirectly from the other channel. But if you get a hum or a buzz then you have a problem.
