S
slbubba
Folks;
I've had the set for a month now and overall I'm happy with it. There are a few odd things about it though and maybe someone out there has some information to share.
Channels: There is no way to do a manual channel add. You must do a scan of the entire antenna input to add channels into memory. There is also no channel delete function. Is there a undocumented way to do either function?
Are there any secret menus that give information or functions that are not published in the users manual?
Is there a source or contact for high level technical information on this set?
Warren
Warren
