RCA Coaxial V Optical Cables?
Discussion in 'Cables & Switches' started by kmhtkmhtkmht, Aug 13, 2005.
  1. kmhtkmhtkmht
    kmhtkmhtkmht
    I am wondering what gives a better sound quality, a RCA Coaxial Cable or Optical Cables?
    I am buying a YSP-1 and trying to figure out how to connect the PC's sound to the YSP-1, and The speaker supports both the Coaxial and Optical inputs and so does my soundcard that can output on a Coaxial or Optical.
    Which connection will result in better sound?
    FYI:
    Soundcard:
    http://www.atruereview.com/bluegears/index.php
    Back of Speaker:
    http://www.newegg.com/Product/Showi...nel+Digital+Surround+Sound+Projector+-+Retail
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,130
    Rainham Essex
    +2,392
    There is pratically nothing between them! In theory coax should be better on a short run as there is less conversion to the signal. Optical should be used on long runs though as it is not going to pick up any interference.
    Mark.
