RCA cable
Discussion in 'Cables & Switches' started by F G Evans, Jan 13, 2005.
  1. F G Evans
    F G Evans
    Can anyone tell me what an RCA cable is.
    I recently bought a Tannoy 5.1 FX surround system and it recomends connecting the subwoofer with a RCA cable plugged into either the right (white) socket or the red (left )socket.
    Am i right in thinking that a RCA cable is simply just an ordinary AV cable which is usually used to connect the audio from a DVD player or TV to an amplifier. ie the type of lead that has a yellow , white and red connector.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    RCA is the name for teh plug at the end of normal audio cables (the hole with a pin in the centre)
  3. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    RCA plugs/cables are also known as "Phono" plugs/cables in the UK.
  4. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    RCA is not equal to an ordinary AV cable but ordinary AV cables use RCA connectors. :lesson: ;)
    For a subwoofer one cable (RCA to RCA) is usually sufficient.
