RCA Cable Splitter Question
scooby l
I've posted this in General too...but thought it might be answered here also!
I want to run 2 Paradigm PS1000's off my one AVC1D sub output, and thought the easiest way would be to purchase an RCA cable splitter...now this is where I come to a sticking point....
All the splitters on the market with 1 male - 2 female (as I would have thought this would be the obvious gender formation) are advertised as 'in car kits to enable one head unit to drive 2 amps'... where as the sub cable splitters are all 1 female - 2 male in gender... meaning I'd have to position the splitter at the sub end of my rca cable, not from the amp directly..which is what normally you would do..?
Am I correct in thinking I can use the 'in car splitter' for the same result? I'm not going to damage anything etc...
D
Deleted member 30535
You'll be fine if you split at either end with either type of "splitter".
scooby l
thanks.... just what I needed to hear!...was starting to wonder if I was being dumb or something..
IronGiant
My preference would be to split them at the amp end and send the signal down 2 cables of the same length anyway, so yes those splitters should be fine.
Dave
Edit: Doh, beaten to it, yes as Malice said
D
I think much depends on whether the 2 x subs are co-located or not. If they were co-located and perhaps facing "back to back" I'd run a single cable from the amp and split at the sub(s) end.
