RCA-BNC Adapter Plug/s required ?
Discussion in 'Plasma TVs Forum' started by bakero, Jan 2, 2005.
  1. bakero
    bakero
    I've bought a Component Video Cable to connect to the PWD6 composite / component video terminal board
    http://www.tvcables.co.uk/cgi-bin/tvcables/CP001.html
    In the operating instructions for the board it shows component out being connected to the board through an RCA-BNC adapter plug - is the component video cable enough, or do I need to buy more ?
    Dave.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Maplin sell the adapters for £2 each ish IIRC CPC are miles cheaper but minium order etc pushes it up £5+ deliver under £30 order Ex VAT
  3. SimonD
    SimonD
    Dec 24, 2002
    134
    16
    Basingstoke
  4. bakero
    bakero
    Thanks - I'll give tvcables a call in the morning and get them to add 3 convertors to the order (....which I think is enough, only need them for the screen, the amp and DVD will be ok without...?!)
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    just need 3 for screen end if screen has BNC component board (or dual slot board) Standard RCA are fine for the rest of the cables
